Z
zander1
hi, 1st post on here so hello.
just need a little advice on contactors. i recently replaced a contactor (8oA, 3pole, 230v coil) but couldn't get it to work, it rattled around and made a right racket.
ive just received a replacement from the wholesalers (after a right dispute) so thought id just check it before i went to the site and replace it again (wired it to a plug/flex and plugged it in) but the same thing happened.
i checked the box which states 230v coil but on further inspection i noticed on the coil itself it says 415v and has an A1 connection and 2, A2 connections.
Now ive never had the opportunity to install a 415v coil before (done plenty of 230v) so i need to get my facts right when i phone my office to tell them whats going on. Am i correct in saying the coil needs to be activated by 2 of the phases (to get 415v running through it) and why is there 2, A2 connections.
That probably sounds like a complete noob question but like i said ive had no experience with 415v coils before and just want to get my facts right as this has caused enough aggro, and if its not my fault then its all good.
cheers.
cheers.
