View the thread, titled "480VAC MCB & RCD required" which is posted in Commercial Electrical Advice on Electricians Forums.
I know its early in the morning norcal, but I find it odd that you have commented on a post that was last dated March. If the OP hasn't found his items by now then he should give up.
I need a coffee. I'm way too grumpy.
True, it's a old post but on a new computer that am slowly rebuilding my favorites/favourites list on as I remember them. Meant to add a "Old Post Alert" as a header, but did not.
I think Schneider do a couple of ranges of MCB's and RCD's that are rated to 500v or thereabouts. We sourced some a while ago for use in a DB that had both phases of a 180 degree split-phase supply in it. I also got some extras for stock at the time so if I remember tomorrow when I'm in the stores I'll get the model numbers and post them.
Reply to the thread, titled "480VAC MCB & RCD required" which is posted in Commercial Electrical Advice on Electricians Forums.
