We have been here before. TIC has a statutory definition, for example here:
http://www.decc.gov.uk/assets/decc/...0100331172153_e_@@_fitlicencemodification.pdf
“Total Installed Capacity” means the maximum capacity at which an Eligible
Installation could be operated for a sustained period
without causing damage to it (assuming the Eligible Lowcarbon
Energy Source was available to it without
interruption), a declaration of which is submitted as part
of the processes of ROO-FIT Accreditation and MCScertified
Registration;
Translating and simplifying, it means TIC = the maximum continuous output of the inverter, or if the kWp of the panels is less than the maximum continuous output of the inverter then TIC = the kWp of the panels installed (assuming they could all receive maximum sun at once).
If the British Gas form only asks for DNC then it is because they are dozy. However in almost 100% of cases for simple solar pv then TIC = DNC so in effect it is not an issue.
And incidentally, although the statutory definition in the legislation says we submit TIC as part of MCS registration, it is only via telepathy, because the MCS registration process asks for DNC!
Regards
Bruce
