4kW installation 200 metres away | on ElectriciansForums
Discuss 4kW installation 200 metres away in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
E
EWebster
Hi all,
I'm quoting on a 4kW installation which is 200 metres from the consumer unit. I've worked out that 25mm cable will be required to compensate for voltage drop.
Can someone confirm this for me, and make any suggestions as to any other gotchas or improvements I should be looking for?
Many thanks
E.
Reply to 4kW installation 200 metres away in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
OK, things have moved on. I have also noticed that the meter tails that were installed in the meter cabinet have exposed inner insulation on...
