4mm alan head screws | on ElectriciansForums
Discuss 4mm alan head screws in the UK Electrical Forum area at ElectriciansForums.net
Coventry
[ElectriciansForums.net] 4mm alan head screws
in this image of an isolator the screws to tighten down on to the tails were 4mm alan heads. I wasn't happy at all, am I wrong? As far as I can see the main thing with am3 was to do with consumer unit fires which 9 times out of ten are due to bad connections.
with this isolator I don't know how much torque I could apply via a 4mm alan but it's not much and well less than a 6.5mm flat head screw driver. and I don't have insulated alan keys so my bum was twitching like a rabbit's nose.
edit; its a brand new meter and isolator.
it didn't feel like it. yes it was dead and proved dead, but still, at the back of your mind your thinking.....what if.
Just do the maths, it's a simple calculation of moments. With an Allen key you are applying the force to a lever a few inches long whereas with a screwdriver you are applying the force almost directly to the axis of movement.
do you not trust your own ability to work safely?
I appreciate your point and agree. however my concern was rounding out the head from too much torque. I'm sure they have been designed and tested and will function perfectly. I'd just rather something a bit more substantial.
just trying to keep it light hearted.
DNO's have been using 4 & 5mm Allen head screws for lots of kit for years around here, Including overhead line taps etc. Never had a problem with not being able to torque them down properly.
If your going to be doing many & buying an insulated Allen key, the T keys are much better to use.
The only nuisance with allen keys is they are not a post origin standard fastener so it is less likely someone has the right tool available, as demonstrated in your post.
If your torque screwdriver takes 1/4" bits then you can just use an allen key bit, though or course you are then limited to the same torque as for a screwdriver.
As Davesparks and Specialist have mentioned the torque that can be applied is greater than with a screwdriver and the standard tooling is the T keys. Though I only have insulated allen key screwdrivers because I am cheap:).
Aren't these 3mm? The trouble with a lot of these hex type of terminals is the screw is substantially smaller than the terminal hole so if the conductor is shoved in and the screw tightened, most of the strands end up in the space either side of the terminal screws. What is really annoying is many of these isolators have proper, full sized terminal screws that are the same diameter as the terminal hole, with slotted heads on the DNO side.
Comparison of proper terminals and the new hex rubbish:
Without getting into the 'torque screwdriver debate' (although I think we will!), clearly it would be possible to overtighten these terminals more so then, than a typical screw head, which I guess is OP's point?
Do we have the manufacturers details, and their recommendations for torque settings?
My torque screwdriver (which by the way needs calibrating), does not accept Allen head attachments, so guess in this case, I would need to purchase another device to correctly torque such terminals.
Incidentally, last time I checked, the cost of calibration was almost the same of a new calibrated replacement ;)
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to 4mm alan head screws in the UK Electrical Forum area at ElectriciansForums.net
