4mm alan head screws | Page 2 | on ElectriciansForums
Discuss 4mm alan head screws in the UK Electrical Forum area at ElectriciansForums.net
Coventry
[ElectriciansForums.net] 4mm alan head screws
in this image of an isolator the screws to tighten down on to the tails were 4mm alan heads. I wasn't happy at all, am I wrong? As far as I can see the main thing with am3 was to do with consumer unit fires which 9 times out of ten are due to bad connections.
with this isolator I don't know how much torque I could apply via a 4mm alan but it's not much and well less than a 6.5mm flat head screw driver. and I don't have insulated alan keys so my bum was twitching like a rabbit's nose.
edit; its a brand new meter and isolator.
Found an insulated Knipex T bar that a local DNO operative had dropped loading his van. Never saw him again so kept it. Best thing I ever found! We have quite a lot of those isolators up here and quite often the MET on the cutout (or Henley block) can be hex heads.
I was informed by one UKPN operative that their guidance on tightening terminals was "as tight as possible" and since they were using the T hex keys that could be fairly tight, if 16Nm is the actual recommended torque perhaps this was not such a bad instruction as I originally thought.
Reply to 4mm alan head screws in the UK Electrical Forum area at ElectriciansForums.net
