4mm spur | Page 4 | on ElectriciansForums
Discuss 4mm spur in the UK Electrical Forum area at ElectriciansForums.net
R
redface
dose anyone use 4mm tw/e now to supply sockets on 32a mcb as a spur if so what distance can you go in plastic 3 compartment trunking reference method c is 37A but methord B is 32A
now as there is only 1 cable in trunking. so i cant see why it drops 5A just to being inclosed in plastic
or dose everyone still use 2.5 ring circuits
there is only so much **** take i would say i have more qualifications than most of you and experiance it was just a question just didnt word it very well
Err, more qualifications but you can't use professional terminology correctly? Take the slapping that's being dished out!
is this guy what you might call one of the `5 a day`...
seems like it these days in here...
[ElectriciansForums.net] 4mm spur
I have put a 4mm radial with about 20 sockets over 70 m the volt drop is 11 ma/m so at max of 13a the volt drop is about 10 V now I have a new question do I take the volt drop from 32 A or what I would say is 13A because I socket will only let you draw 13A
If anyone want to correct me then do it but not like a little boy
20 x 13 = ?
Have to be honest, 18 years experience, this is kids play, college stuff, I understand you want to ask questions about things, but you should already know basic stuff like volt drop, ccc and disconnection times
Reply to 4mm spur in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
