4mm t&e radial circuit | Page 2 | on ElectriciansForums
Discuss 4mm t&e radial circuit in the UK Electrical Forum area at ElectriciansForums.net
sjhall
na
Hi Lads
Do any of you guys run radial socket circuits ( with multiple points ) in 4mm ? Do you find 2 x 4mm in the back of a socket a squeeze?
Only asking as I've just been passed 2 x 100m drums of 4mm off the lad doing the solar on a job I'm on for doing him a favour.... so 4mm radial... pain in the --- or not so bad ?
Cheers
Appendix 15, figure 15B, page 506 of the BBB calls it that.
But they don’t know sh.. you know what. It isn’t actually a spur in the case of a radial. It’s a branch.
Oh lord forgive me, I’m actually agreeing with “him”
I almost did, but I just can't bring myself to discuss whether it's called a 'branch' or a 'spur' :D
Reply to 4mm t&e radial circuit in the UK Electrical Forum area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
An extra joint box isn’t a massive issue… use a wago box, with proper wagos. Nice and small will fit up through downlight hole. Wago box should...
