5.7kw Hob | Page 3 | on ElectriciansForums
Discuss 5.7kw Hob in the Australia area at ElectriciansForums.net
U
ukpita
Quick question... Electric hob is 5.7kW so could I use 2.5mm heat resistant flex? B+Q has Tower 2.5mm Heat Resistant flex and says that is max rating is 240v, 6000Wats and 25 Amps.... so i think this would be ok?
Just wondering as 4mm is mentioned as the standard however 4mm would be a little difficult to run/connect?? Guess im just looking for a second opinion.
Reply to 5.7kw Hob in the Australia area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
