5 cables into one don't go? | Page 2 | on ElectriciansForums
Discuss 5 cables into one don't go? in the UK Electrical Forum area at ElectriciansForums.net
DeanUK
Southampton
Hi, hopefully you can help.
I am installing 5 external floodlights in the garden. The units have a 1.5 mtr cable with a 13amp plug. I am fitting these around some new decking and the cables are to short. So i want to join them all up using 121 cable connectors to extend the cable a cpl of mtr's. to a single junction box and have one cable coming out of the box. and run them from a single cable with a 13amp plug into an external socket. Now i cant seem to find something that will join all these wires into a single wire for the plug.
Can i put 4 lives twisted together into a single block and the 4 neutral and then 4 earths, then just put the plug wires into the block. Do i just need a bigger size block to fit all 4 cables into one hole?.
There does not seem to be a block where the live wires etc are all joined.
Attached a layout and explanation
  • wiring layout.pdf
Right last thing, and i'll leave you alone..lol these should do?
Reply to 5 cables into one don't go? in the UK Electrical Forum area at ElectriciansForums.net
OK, thanks, I see the speaker now. I imagine it's 'home-made'. If the modules you mention are powered directly from the mains supply, their...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
