5 core flex to combi | on ElectriciansForums
Discuss 5 core flex to combi in the UK Electrical Forum area at ElectriciansForums.net
Bellendian
Gatwick
Need to wire a supply to combi with LNE connections, and 2 volt free cores for room stat.
I don't really see why I can't use 5 core flex for this, as all cores insulated to 500v, but plumber insisting they need to be in separate flexes...any thoughts?
Cheers
Cheers
Plumber is wrong. End of.
Cheers,
This is a Worcester. Will get him to check mi tomorrow and see if this is what he's on about...annoying if I need to run in a second flex though!
Out of interest what Worcester? I haven’t touched one for a little while now, but I’ve never come across a Worcester with a volt free connection.
Interesting....I haven't seen it yet....but that is the spec I was told...Will get details tomorrow on model and mi and get to the bottom of it. I suspect plumber has got wrong end of stick, all I know so far is that it is an older model that is being relocated.
I’m doing 2/3 Worcester’s a week at the moment and none of the current models need a volt free roomstat, they are all 240V for standard controls.
I wonder if the water clown is getting this confused with using the Ls terminal to supply external controls.
Reply to 5 core flex to combi in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
