50 year old radial sockets at floor level
Just a case of Cart Leading Horse..... their are a lot of head strong customers out there that think they can dictate and get their own way regardless of the reg's you have to follow... its just a matter of expressing requirements and where you can make allowances due to the listing of a building if that be the case.
Golden rule.... dont let the customer dictate the job they should only give what they prefer and not demand ... if its means you can't meet cuurent regs then you need to evaluate whether it will impact the safety of the installation and if it does not then a deviation from the reg's can be called under certain situations... i.e listed building etc
why would i need to pull up 2 T & E's if there's more than 1 socket for a radial circuit?
Can't believe you just ask that, if a radial of sockets has more than 1 outlet the all the socket before the last one will have 2 x t&e at them..... or have i misread your response ?
Thankyou for this post....can go to bed with a smile on my face!!!!
Junction box to junction box is not good!
but you won't have 2 T & E's in the same conduit! you'll have 2 T & E's in the same connection box, but that's not what the guy said! one goes one way, one goes the other!!
Eh? how else would you wire a radial circuit? you're joking, right?
So your going to run radial to many junction boxes under floor, then spur aff these up your conduit and into te socket?
- - - Updated - - -
Spur off these. I ment
E4u is saying a pipe feeds a socket and another pipe feeds the next,if that's so he will be pulling one 2,5 mm ( but as I said earlier a 4.0mm would be just as easy)
- - - Updated - - -
It's very simple.The conduit runs from the CU to each socket backbox.there's 4 sockets on the circuit. there's no juntion boxes. this is a 50 year old installation.
It’s about time the plug was pulled on this fantasy thread. That’s if anyone can bend down low enough to reach the socket!
Thread temporarily closed by request. I'll leave it to the mods here to discuss whether it should be reopened.
electrician4u,
Dan,
