View the thread, titled "500w Dimmer unit" which is posted in Commercial Electrical Advice on Electricians Forums.
The OP is looking at 360w of LED so I'm thinking you idea might not work for very long!
3rd comment.......What options is there to control x 24 (10-15w) led's ??
24 x 10 = 240, so the Zano is an option?!
He could go crazy and even add another lamp lol
They do a two gang version so you can fit 500W of LED dimming on the plate although obviously not the ideal solution as you would have 2 circuits.
BUT this is for an existing set up so there maybe only 1 switch cable at the switch!
could do with more info TBH
And there was I thinking that each led lamp ratins need to be timsed by 10 the account for start up. So 24 led lamps rated at 10 w each would need a dimmer with a rating of 2.4 Kw; so i looks like your 500w dimmer wont cut it ! All 24 lamps are on one switch !
Zano Zbar LED controller have a look at that. Then use a rotary analogue switch with it. Costs about £125 ish. Talking to Zano they use 1.8 x load to calculate inrush which is about what fluors were/are. However each manufacturer has differing inrush currents and you would have to look at their site or tech dept. for proper info regards inrush.
Thanks I will have a look;
1.8 of a lamps load to compensate for inrush seems a bit low in comparison to the general (x 5 - x 10) recommendation within the google ether; although any specific compensation must be lamp dependant which im guessing Zano is basing the 1.8 on. I will call them tomorrow but I would hazard a guess its more like 1.8 - 10 depending on lamp. Might be wrong hopefully.
As said @haptism you have to look at the manufacturers data for inrush current and it can vary wildly there is no rule of thumb it can go from (for a 44w 600 x 600 panel say) 10A to 40A per fitting dependant on manufacturer and control gear.
Maybe bit late now to reply but did similar job last year (in a church) using Zano ZBarLed 1000w dimmer with rotary controller (approx. 300w of dimmable LED), worked a treat!
Reply to the thread, titled "500w Dimmer unit" which is posted in Commercial Electrical Advice on Electricians Forums.
