500WATT outdoor light by danwithbigheart | Page 2 | on ElectriciansForums
Discuss 500WATT outdoor light by danwithbigheart in the Australia area at ElectriciansForums.net
Hi my name is dan, or dantheman; me and my dad who is a qualified electrician have fitted an outside light. The problem being is this i have done it in the following way i have connected the live and neutral from the ceiling rose in the kitchen to a two gang switch in the kitchen next to the back door. I have then connected from the two gang switch in the kitchen to the light outside with a live and neutral and all of this is earthed. Problem being is im not sure where to connect the live and earth to the switch which being where. I am only a young man i suppose you would say as i am 27 and just starting out with my wife and 1 year old in a new area with new surroundings etc and a new house what is the easiest solution and am i doing anything wrong?.
Reply to 500WATT outdoor light by danwithbigheart in the Australia area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
