I have a problem with a 50A Solid State Relay - the output on side 1 is fine at 230V however the output on side 2 when switched is only 120V. The load is two heating elements. First thing I did was change the relay for a new one but the funny thing is when I install a new relay I get nothing coming from side 2 when switched? (I tried two brand new relays both like for like with the one installed before).
This means that the elements are only getting half power and are not generating the correct heat for the warming bin.
Would appreciate any ideas anyone has.
