Hi all,
After some advice.
i have a run of 50mm 4 core on a farm to reinstate some GP buildings.
100A feed, with fused disconnect at the origin.
in its run it needs to be intersected to feed a small existing 3phase board just for some lightingin a tractor shed.
my thoughts are use a non fused isolator. The only issue im finding is sourcing one I can get x2 50mm cores into the incoming side none I can find (for a decent price) use lug mounted posts.
Other option in my mind is a busbar chamber?
Any help much appreciated!
After some advice.
