50V insulation checker hire | on ElectriciansForums
Discuss 50V insulation checker hire in the UK Electrical Forum area at ElectriciansForums.net
UKMeterman
Hi,
Any suggestions where to hire a 50V megger, I have a telephone installation where the BT fault checker is reporting low resistance and a standard multimeter can't do the job.
Ok, I will try 100V, I know it is not the main issue there is no ring trip there is a problem with the line card at the exchange, but untill all faults are cleared on the extension wiring i can't progress the fault. Bt openreach sent out a 18 year old "telephone engineer" who replaced the master socket and then did not connect the extentions as there were two sets of wires at the master socket plate. I was not impressed.
If it has a new master socket then they should be able to disconnect all extensions by unplugging the front part of the plate, then they can test everything on their side of the master socket without worrying about whats on your side. That is after all the whole point of the removable front plate arrangement.
Reply to 50V insulation checker hire in the UK Electrical Forum area at ElectriciansForums.net
Hi. Sorry if this is not allowed, but I'm on the hunt for my first electrical role. I've completed C&G level 1,2,3 currently doing my 18th...
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
