Hi all,
Doing a new build barn conversion installation and the lighting has been designed by a consultant. They've specified some 5A sockets for plug in lamps.. never done these before although I know the plugs and sockets are available.. round pin type.
Some of the arrangements are for 2 way switching so am I right in thinking the only way to do this is to treat the socket as basically the lamp and switch it locally using standard 2 way switches and intermediates adjacent to the sockets?
I'm planning to use dedicated 6A radial circuits using 1.5mm t&e does this sound ok?. There are a maximum of 6 outlets on each radial ..
Cheers..
Cheers..
