View the thread, titled "6 Amp RCBO 13 Amp load" which is posted in UK Electrical Forum on Electricians Forums.
Top Cat
Doing a rewire at the moment in an empty house. I am using RCBO's mostly so when i got 1 room complete i wired the 4mm radial into the RCBO so we could get the kettle going.
After several brews i went to disconnect it only to find i had wired it into a 6 Amp RCBO!
The trip never operated once with a 3 KW kettle on it. It was a Square D RCBO.
Going to swap the breaker on Tuesday when the merchants open but surely this should not happen.
Reply to the thread, titled "6 Amp RCBO 13 Amp load" which is posted in UK Electrical Forum on Electricians Forums.
