6 way consumer units | on ElectriciansForums
Discuss 6 way consumer units in the UK Electrical Forum area at ElectriciansForums.net
Hi, What type of consumer unit would you install in a residential property when there's only about 5 circuits?
3+3 boards are super expensive 5+5 split load boards always seem to be the cheapest but seems a bit overkill then it's a few too many rcbo's to make it financially viable. Do people ever use single rcd main switch consumer units at all now?
Personally, if there is room for it, just put a 10 way in. It's not really overkill, just a few extra inches, we could all think of something to with that sooner or later.....
In short, no, unless its to cover one additional circuit. As in one MCB. MAYBE TWO!
leaving spare ways is not overkill......
Definitely wouldn't use rcd as main sw for all circuits. If I put in a new c/u for a customer I'd always have a few ways spare. You can pick up a 5+5 arrangement for around 70 quid. 5 rcbo's will cost u more than that.
But using 5 RCBOs is just better for the sake of 20/30 quid!
And how exactly would that comply with the regs?
Changed a board in a house the other day. Only had 2 circuits.....Sockets and lights. So it was 2 x rcbo's. Was gas heating and gas cooker. Fastest fit of a cu in my life. The bonding took me longer to do.
If you are short of space for a 10 way and definitely have no more than 5 circuits, I'd point out that Wylex make a 7 way dual RCD (or even high integrity!) CU. Crabtree make an 8 way dual RCD. If customer is on a tight budget CED/Excel (same product?) also make an 8 way. These are just examples.
I had to put one in last week, had a gap of about 310mm, put an 8 way rcd main switch in, was about 280mm wide I think. I don't particularly like doing it but needs must.
Reply to 6 way consumer units in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Thank you, that's a really helpful post, nice & clearly stated and helps me clear up a lot of confusion on this matter.
2 3 4 5
6K
