K
keynotez
Hello folks! I'm just a newbie here. I'm just confused where did the 60 Hz came from even at 0 volts on the line. I have a data gathering at a generator set using a HIOKI power analyzer. When the generator shuts down, of course the voltage at the lines are zero and the frequency MUST be also zero, am I right? I'm really confused that right after it reaches a low frequency (e.i. 35 Hz at 0 volts), it will now rise to 60 Hz all through out the recording period. Where did that 60 Hz came from? Any help will be much appreciated. Thank you in advance...
