Hi everyone,
A friend of mine has asked me to take a look at this vintage 60s lamp which is running a little hot on the 'HIGH' setting. It has a transformer in the main plastic body which converts the mains to 12VDC. There is a single positive wire running from the transformer through the metal shaft to the bulb (presumably via the ON (HIGH) - OFF - ON (LOW) selector switch on the main body but I can't get to this at the moment). The negative from the transformer is connected to the metal shaft which is continuous with the -ve of the bulb. The bulb is basically a 12v car bulb. The wattage on the bulb currently fitted is 21W 12V. The rating on the sticker on the lamp says 20W 12V.
The mains lead is in ok condition but has no earth and no outer sheath (as you can see in the picture - old skool!)
Couple of questions...
1. Is it safe to have the -ve from the DC output connected to the metal shaft?
2. Should the thing be earthed. If so then should I attach the earth from the mains to the metal shaft?
3. Why might it be running hot?
4. If I put in a lower wattage LED bulb instead of the filament bulb - as in maybe 5W instead of 21W - would that be bad for the transformer?
5. Should the mains lead be replaced with sheathed 2 core?
Cheers
Tom
Cheers
Tom
