63A dno fuse | on ElectriciansForums
Discuss 63A dno fuse in the UK Electrical Forum area at ElectriciansForums.net
cf46
years ago the dno fitted a 63A fuse but over time my needs have grown. is it a case of just getting the dno to fit a bigher fuse or are there other bits involved. meter tails are 25mm and about 0.5m long.
kind regards
As above get the DNO to do a site assessment and see. Very likely they can upgrade you to an 80A fuse, but they must verify first.
Do you have concerns you are using more than the fuse rating ?
his cannabis plants will benefit from 80A. :(:(:(
Reply to 63A dno fuse in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
