? 6mm = 2 x 2.5 mm cables | on ElectriciansForums
Discuss ? 6mm = 2 x 2.5 mm cables in the UK Electrical Forum area at ElectriciansForums.net
Berkshire
Hello peeps.
Okay, I should read regs. instead of just ask those who might know, but it's easier :)
Do you think it acceptable to use a short length of 6mm t&e in order to link a new consumer unit to a 'head' (the former CU position) of an existing final ring consisting of the normal two 2.5's? (about 400 mm length.)
I only ask because I am curios whether this could possibly look neater.
Thanks for your thoughts.
Hello peeps.
What else exists at "the head and what do you mean by "the head"?
given we are talking quite a small distance here, why not just get a suitable enclosure and use some connectors to extend with the same cable? wont cost much for a little box and connectors, will look nice when clipped and dressed well for the customer though. its better than bodging it with a bit of 6mm. If you really want to be fancy get a small enclosure with din rail and use the din connectors. they look really nice when dressed well to extend the circuits to a new CU position.
Hello peeps.
Yes, called a lollipop circuit.
I wouldn't want to be the one trying to squeeze 2x 2.5 and a 6mm into the back of a socket!
There was an article about this type of circuit arrangement I think in the voltium email I get not so long ago, FWIR. They said that this was an acceptable way of supplying a ring final circuit as long as the joint with the 6mm was accessible to facilitate test and inspection.
JB then. I presume that's what he's on about at the former CU position. 32A dp switch may suit better.
Oh yes, thank you guys, great replies.
Glad I know now what a Lollypop circuit is, inthe past I would've been tempted to give it a good ol' lick for a quick live test .
...only kidding. Thanks for your thoughts people, I'll stick to the solid path.
Reply to ? 6mm = 2 x 2.5 mm cables in the UK Electrical Forum area at ElectriciansForums.net
