700W High Bay | on ElectriciansForums
Discuss 700W High Bay in the Lighting Forum area at ElectriciansForums.net
gr7
Hampshire
Does anyone know where I could get hold of a 700W high bay fitting? I need the circular type with a reflector to replace a faulty unit. My customer is not interested in converting to LED at present, just wants the failed unit replaced.
Makes no sense.
Swap it for a LED of equivalent output. It will probably be cheaper the sourcing a 700w discharge fitting.
I presume you have called the wholesalers?
Yes, I have spoken to wholesalers. LED does not give the same light as mercury, this is apparently important as the hall is used for badminton/tennis. It would be okay if we changed all six fittings to LED with the appropriate gel but they do not have the budget for this.
I still don't understand, the LED equivalent colour temp and wattage would be fine for knocking a yellow fluffy ball around
The 700w lamps with a E40 cap seem easy to get, just no fittings.
Is the fitting 100% dead? New cap or ballast maybe?
Reply to 700W High Bay in the Lighting Forum area at ElectriciansForums.net
    • Friendly
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
