i=p/u - Arms Jan 1, 2013 #16 Just redo you calcs for the load and cable length , you know quick fix is £100 a flood from jcc, 30w =300w equivalent
P plugsandsparks - Esteemed Arms Jan 1, 2013 #17 Even cheaper is a couple or 4 off 36W CF floodlights, last ones i put up were £25 a piece, cope better with the voltage dips you are getting.
N Nivag316 Jan 2, 2013 #18 Try firstlightdirect.com. Look under 25Watt-R7s-Low-Energy-Replacement-118mm-Long-Warm-White_A105GG.asp. Also available from Newey and Eyre for £10ish
