Hi all,
Been a while since I've posted - got a new project to install a small 7kw electric shower.
The shower will be about 7 metres from the main fusebox on the upper floor.
There seems to be a lot of debate about 4mm2 or 6mm2 wiring.
Due to the diameter of the wall conduits, I doubt very much I'll be able to fit 2 x 6mm2 cables in there so I was thinking of 4mm2.
Obviously, I want to keep it all safe. Would I get away with 4mm2?
If I used 4mm2 would I need to keep it outside of the wall in the air?
The house has electric underfloor heating and all is cabled with 4mm2 also between the lower and upper fuseboxes (short distance about 1.5 metres).
We rarely use the underfloor heating on the upper floor - only the small bathrooms rated at 300w.
Both floors have the usual master circuit breakers, RCD's etc.
The house is installed with a 'three phase 2 wire corner grounded delta' btw
Thanks!
Thanks!
