Hello, I've read a few similar threads online but none come up with an answer.
I recentally replaced a 7.2 Kw shower with a Triton 8.5 Kw shower. But trips the mcb after of running the shower for 20 minutes.
While installing the shower I replaced the 6mm with 10mm T&E, and the 50 amp pull cord Isolator.
The cable runs 50% conduit 50% open air. 9 meter cable run
MCB Wylex 45amp
The cable stay's cool while running but the mcb gets very hot
Clamp meter reads 35.1amps.
and checked for any loose connections
MCB Wylex 45amp
