T
Toneyz
Can anyone recommend a supplier for the above we have had some from a previous supplier but have failed.
Discuss 8 foot LED replacement tubes in the UK Electrical Forum area at ElectriciansForums.net
just get loads of LED strip kits, if you can fit the transformer inside the fitting, i did this for a load of outside lights when customer didnt want new fittingsThe client does not have the budget for new fittings it is a take guts out and change to LED tubes as the title the existing that were fitted have not performed as advertised we have been asked to replace hence the ask for recommendations we very much want to change the fittings but it is only a storage depot and this is what they want to pay for.
Thanks for the feedback.Fitted 23 of these in the last 12 months and no problems to date.
2400mm (8ft) T8 LED Tube - https://www.ledsave.co.uk/2400mm-8ft-t8-led-tube.html
The britesource lamps above are also available from lampshoponline who are good for service and will give u a 5% voucher if you message them, big clive did a teardown of some britesource E40 corn lamps on youtube and for an off brand were very solidly made electronically, i fitted some 3 years ago and 1 has just failed this week, theyve been in a carpark in use 10hrs a day the whole time.
Ive only used 5' britesource led tubes and they were plastic not glass so sagged a bit, id contact them to find out.
T8 8ft 2400mm 42w Led Tubes at LampShopOnline Ltd - https://www.lampshoponline.com/led/t8-led-tubes-high-quality/t8-8ft-40w-676-led-tube-frosted-extra-high-output.html
Come down in price in quantity aswell
Reply to 8 foot LED replacement tubes in the UK Electrical Forum area at ElectriciansForums.net
