9.5 kW shower on 2.5!!! | on ElectriciansForums
Discuss 9.5 kW shower on 2.5!!! in the Talk Electrician area at ElectriciansForums.net
Newcastle
I was doing a eicr today. Came across a shower 9.5 kW Mira ,which had been installed for at least 8years.
its was brutally spurred off the bathroom heater which was protected by a 15'amp rewireable fuse. All, done in 2.5 t&e .
The client swore he knew nothing about it, and said he did have someone change the shower a good few years ago .
He also claimed it had never blown the fuse , I checked it was 15 amp wire , and I can only assume on cold days the heater was on as well and the shower was working hard.
Bizarre
To be fair the cable was still in good condition and belled out at 299.
whats going on here folks. It dosent add up!!
I saw one once connected to the upstairs lighting circuit with a 30a wire in the 5a 3036 fuse. The 1.0mm cable had completely melted where it passed through insulation,but was visually undamaged in free air. It was chased into the wall on the drop to the CU and the heat damaged several of the cables chased in alongside it.
Householder had only just moved in....lovely surprise for them!
Bizarre
Belled out? whats that
It's more commonly used to refer to a continuity test Pete, even more odd.
I realise what it means but as an Apprentice he should be taught to use the right terminology "belled out at 299" what apples sorry Ive got a headache and that sort of thing really ticks me off.
too mmuch of the red?
I'm really sorry my terminology annoyed you so much, consider me well told off and I will stand in the corner for 20 mins.
Its a common terminology up my way. I assume it comes from the old testers which basically were an audible continuity.
i applied 500 volts to the cable and it gave me a reading of greater than 299 ohms. Hope that helps.
299 Mohms you mean, Don't forget the dunces cap, and you have detention for the next week
I hope you realise that you have to go in 'the naughty corner' 1 min x age. So unless you are 20 years old then the time needs altering..... :)
Most showers have 2 power settings, maybe its always on the first one.
Reply to 9.5 kW shower on 2.5!!! in the Talk Electrician area at ElectriciansForums.net
    • Winner
