9.5kw electric shower | Page 2 | on ElectriciansForums
Discuss 9.5kw electric shower in the UK Electrical Forum area at ElectriciansForums.net
Edij
West Drayton
Hi ,
I'm getting electrician to change my consumer unit and was planning to get :
it has 2 x 80a 30ma Type A RCD's
but for shower it says -
500 (9.5kW)41.345A10mm2RCBO
will this 80a fuse not be like overload or something? Do i need to buy 40-45A fuse?
According to the BEAMA guide that somebody posted the other day, it is. We never fit split load boards but according to this documant diversity IS taken into account when selecting and erecting.
If you have more upto date info can you share please?
Hi. It was me that posted the BEAMA document.
Apparently there is a 2 stage process when applying diversity to a group of circuits protected by an RCD.
Stage 1 work out and apply diversity.
Stage 2 read manufacturers literature.
Excerpt from BEAMA document:
"Conclusion
The minimum rated current Inc of the circuit in the consumer unit for the RCCB
(A) based upon diversity is 78.4 A. However, overload protection shall not solely be
based on the use of diversity factors of the downstream circuits, see Regulation
536.4.202. To achieve overload protection of the RCCB circuit, the rated current of
the OCPD shall be selected according to the manufacturer’s instructions
, which for
BEAMA members, is coordinating with the upstream OCPD, in this case a 100 A fuse.
Therefore, the required minimum rated current Inc in the circuit of the consumer unit for the
RCCB (A) is 100 A."
So, overall, not much point in calculating the diversity?
Reply to 9.5kw electric shower in the UK Electrical Forum area at ElectriciansForums.net
And have a very merry Christmas and a great new year all
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
