View the thread, titled "900W Inverter" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
P
pcollins
Hi All,
I'm looking at a job for a housing association which in includes a number of properties which will only take 4 panels!
Does anybody know of an inverter that'll do a system this small? The nearest I can find is SMA Sunnyboy 1200 but the minimum voltage for this will be borderline and I'm not sure it would do the job so looking for alternatives.
Cheers
Paul
Stecca grid 300, or 500 - i should add, you can use a master like the 500 and have slave's such as the 300.
Thanks all for the replies, I'm looking at something like 4 x Suntech 245's, so 980 watts total. I like the idea of the Stecas but think the current will be too high for them and will limit output. Panels are not currently set in stone for the smaller houses...
I think Mastervolt make some smaller inverters, they have an office somewhere near Portsmouth.
Also Dorfmueller inverters have some smaller models around 900W. I think they are also called Eurolines in the UK.
Reply to the thread, titled "900W Inverter" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
