A
aliuk
Hi,
Currently I have a gas hob and electric oven which are both built in. Unfortunately, I have had to disconnect the gas hob because there is a gas leak and the gas connection is illegal as it uses a flexible hose and apparently for built in gas appliance it needs a solid copper pipe connection.
I've always liked the look of a flat electric hob so I thought I would replace it with a ceramic hob. I have had two local sparky come out and take a look. From what they have said is that I currently have a 6mm cable and a 32A fuse. They said if I wanted to just replace the hob I would need another dedicated circuit because of the power that is required. TBH I would like to replace the stove as well so I'm thinking of simply removing the old units and cutting out a section to fit a free standing unit.
One of the sparky said that it shouldn't be a problem if I can find a cooker that consumes a max of 9kw else alternatively I would need him to replace the 6mm with a 10mm. The one spark gave me a estimate of about £250 - £350 to install and cut out worktop etc to make space for the unit.
Does anyone know of a free standing ceramic cooker that consumes 9kW and is 60cm in width? I've tried google but have found a lot of sites either dont list the consumption or simply list the consumption for the main oven and grill.
Any advice greatly appreciated.
