A Bad 3-Way Switch Can Cause Failure of the Other? | on ElectriciansForums
Discuss A Bad 3-Way Switch Can Cause Failure of the Other? in the Lighting Forum area at ElectriciansForums.net
VFNVFN
NY
Can a bad 3-Way switch cause another not to work, thus preventing either switch from turning on the light? Is this always the case?
short answer, yes it can.
check it out with a volt meter and you will know.
YES ! FOR SURE. 3 way switchs are wired differantly to normal switchs, and if you look at the circuit for a little while, you will understand why !
  • [ElectriciansForums.net] A Bad 3-Way Switch Can Cause Failure of the Other?
Thanks for the replies.
I was told that by an electrician's assistant and to wanted to verify.
Is it always the case that if one 3-way is bad another won't work? And do switches have a life span?
Thanks again. Really appreciate your time.
Reply to A Bad 3-Way Switch Can Cause Failure of the Other? in the Lighting Forum area at ElectriciansForums.net
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
