a bit of explaination please | on ElectriciansForums
Discuss a bit of explaination please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, not a pv installer but was woundering how the fits people stop someone having some pv installed and then connecting up a gen set and getting paid for producing power with diesel? I am on another forum and no one seemed to have an answer
cheers
Vince
If I understand this correctly you mean fiddling the generation meter by feeding it with a diesel generator? Nothing to stop you if you're that sort of crook. Doubt the cost of diesel would make it worthwhile though...
SAP calc on MCS certificate gives a good idea of expected annual generation, anything much more than this and they will be suscpicious
So, it's not worth doing in the first place and you wouldn't get away with if you tried.
Apart from that it's great idea.
(shuffles off to garage to turn off the gennie...)
now if you hooked up an alternator to a pushbike that's still renewable, cost effective and good for you ( still wrong) but would not add in much of anything enough to be noticed,
I was not planning on doing it, as i can't have panels even if i had the money to get them installed, it was just part of a discusion on another forum.
So the bottom line is that recorded output must be close to the projected output, if its not you will get a visit.
cheers
If I could somehow channel despair into the generation meter then I could possibly power the national grid single handedly.
Reply to a bit of explaination please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Welcome back! I bet your old account just got caught up in a clean up if it wasn't logged into for 5+ years it would have for sure been caught in...
