A bit of fun, guess the quote
So second wet pants + his carpenter buddy wanted nearly £3000 to fit a loo , sink and do a bit of flooring
think I will be using first wet pants
If I was still in the trade of fitting kitchens and bathrooms I'd travel down and do you this myself. Assuming it's as straightforward as 2 days for a tradesman and his mate, then I'd be charging around £900 - £1100 labour only, and including travel & one night stop over.
Wren just quoted one of my customers £400 to put 5 sockets back on as part of a kitchen fit! Everything already in place, just the three connections each.
My reaction was disbelief. My day rate is £240, or £60 for first hr then £30 after. £400 is extraction the urine. Especially as we know it's not going to be a sparks who does it.
the independent kitchen company I work for charge £750 a day + materials to the customer for electrical alterations, I think the gas man to connect / move any gas pipes is something batty like £500 per half day.
my sister was just quoted £24,000 by howdens to fit a new kitchen , Labour rates must be in excess of £1000 per day
Unbelievable figures them.
OMG! This is scandalous, I spat out my coffee in disbelief!
So what is the material / labour split on that £24,000 and what is the contribution to the chairman and chief execs bonus
That's a quote worthy of Winston Churchill.
scary thing is she nearly went with it and was seconds away from signing the order when she called me ask if imo was it a fair price
I told her NO, £24 grand is way expensive and to shop around
we did out kitchen 5 years ago using an independent company for £6500 and our kitchen is the same sizes
So , took the day off today and fitted my new sink / toilet unity unit
quite a fiddly faffy job as had to cut several bits out of the back of each unit (so bought myself a new jigsaw) so for the pipes to come across but apart from that it went in fine
now all that’s left is to pull up the old flooring , lay new 5mm ply as instructed by the flooring company in readyness for the new LVT
saved myself over £1000 in Labour
Who Needs a Wet Pants
