hi, could you guys answer me a few questions please.
firstly should main bonding always be done regardless of earthing arrangements.
secondly should supplementary bonding in a bathroom be connected together and then to an earth terminal
thirdly a property with tt system no rcd protection old 3036 board, requires a shower does not want to upgrade board :
1.can you come out of the top of 32 amp fuse to a shower unit encloser with rcd, would this require a mcb or just the rcd as you have overcurrent protection from the fuseway.
2. could the meter tails be split via a henleys block then fed to a shower unit. and i presume this would have to incorporate a mcb as well as rcd protection.
3. would you use 63a 30ma rcd or could a 40a 30ma rcd b used in both cases
thanks for any replies. please note this is for homework only i do not intend to do any job. second yr 2330 just trying to get my head around a few things cheers
