A little bit of info needed please (starting out) | Page 2 | on ElectriciansForums
Discuss A little bit of info needed please (starting out) in the UK Electrical Forum area at ElectriciansForums.net
B
bf2k
Hi all. I was wondering if some of you could possible give me a but if advice. I've been asked if I want to do inspections and any repair work for a landlord on his houses he rents out and any future houses he buys, in my own time at evenings & weekends. Perfect type of work but I've had to turn the work down for the minute because I've been lead to believe that I would have to be part of a Competent Persons Scheme (NICEIC, etc) to be able to do the inspections (and obviously any notifiable repair work). Is this true? :confused5:
I passed my domestic installers qualifications last September (C&G 2377, 2382, 2393 & EAL Level 2 Part P for domestic installers) through New Career Skills - not a place I would recommend in a hurry. Long story short why I choice this type of course. I already did a lot of the theory work prior to taking this course in my Engineering HND qualifications a good few years ago, so already had a good background knowledge of electrical systems. I was made redundant as a design engineer and went for additional strings to my bow to open up job prospects (lucky a friend set up his own design house so I didn't have to wait that long to get back into work). I know now it was probably not the best route to take but I'm here now so it's time to start paying back the ÂŁ6k it cost to do this course.
I've undertaken quiet a good number of minor works jobs, mainly for friends & family and then their friends & family. I've also done 3 notifiable jobs (2 complete re-wires and one feed to an outhouse). I (or should I say the customer) paid the extortionate building control fees of ÂŁ175 for the work to be inspected and passed no problem. I've also done a bit of "experience" work with an electrician we used at work who was semi-retired. I know I'll have to join one of these schemes soon but I wanted to get a bit more experience under my belt and be in a position where I could do this as a full time job as well as looking at possibly of going for the NVQ quantification.
Hi
A little update on how I went on (for those who care :))
It was something of a minor disaster of an installation really. The CU was buried behind an old gas boiler (which had been decommissioned) with about 20mm space between the side of the boiler & the front of the fuse carrier. Thus I wasn't able to actually isolate the system :uhoh2:. So I could only do the visualisation checks. I'm recommending that the boiler is removed and then I'll go back and do a full test on the whole installation. I suspect it will fail because I have doubts that there is adequate cpc on the lighting circuit.
I'm in the middle of writing out the report (the little of it I can) which I can publish on here if anyone wants to have a look to see if I have missed anything or made a glaring mistake.
Thanks for your help so far. Cheers Andy
What absolute twonk but that boiler right in front of the fuse box, they could of at least got it moved first
What happens when a fuse blows??
Cert looks ok so far(even though your unable to do most of it)
Few Small observations; i would think that the earthing system is either a tncs or tns rather than a tnc
also i personally would of coded the cu problem a C2 rather than C1
My point exactly to the house owner
I only put it as C1 because I didn't know where a gas supply was still going to the boiler and because you couldn't get to the fuse carriers. In case of emergency I don't know how you would isolate the supply. I've submitted the report to the guy who asked me to do it and he's forward it onto a housing association. I said I need the boiler moving then I can test and recommended a test of the whole installation. He's asking to go one further and go for a full re-wire...typical builder :)
Thanks for your comments Welchyboy
Reply to A little bit of info needed please (starting out) in the UK Electrical Forum area at ElectriciansForums.net
You need a galvanic isolator in the earth coming from the shore power. If using lithium batteries you will probably need a dc-dc charger to...
davesparks
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
