Just quoting for a C/U change, scenario is:-
O/S meter box, PME, existing 60A switch fuse in meter box, 16mm TWE from switch fuse to C/U in center of house with 16mm TWE coming down wall to C/U embedded in plaster, no bonding to water or gas.
Because the C/U is situated in center of house and all recently decorated it is virtually impossible to get anything new to it.
What i want to do is fit a 100A, 30mA, time delay RCD with 63A MCB in outside meter box.
Run 10mm G/Y to water and gas from meter box.
Change C/U.
I would love to upgrade the earth from meter box to new C/U but i don't think it is an option (obviously only 6.0mm earth in 16mm TWE).
Is this a "hanging offence" or do you think it is OK?
Change C/U.
