A not so great fault today | on ElectriciansForums
Discuss A not so great fault today in the Australia area at ElectriciansForums.net
Essex
I had a cold callout today that i should share as you all will at sometime come across but even with all the info things can go in strange directions.
bit long but worth a read.
Was called out by a new client enquiring about having a new consumer unit today, on arriving i looked at his existing board which was 16th design but only the shower and garage sockets on the protected side, all lighting and other power only has overcurrent protection. Earthing and bonding all up to date so was thinking , Why the call ? as i know its not fully correct but seen alot worse, so asks the obvious question why ''he'' thinks it needs changing.
He said its because the fuse clicks off and wont stay on for one of the lighting circuits. So know its changed to a possible lighting fault that needs addressing first off, now this is a bungalow in well to do area about ÂŁ800k's worth and only four rooms affected on a 6amp mcb but wont stay in and giving a fast hard rupture so said i would come back later and sort it out as it cant be much and should be an easy fix.
Great bit of fault finding for the boy to find while i drinks me earl grey tea chatting i thought, with some posh biscuits.
Turn up and three of the rooms have slidelock roses and the kitchen has a 20yr old florry so know where my money is at this point.
Lets have some guesses what you would have done or any ideas what you may find on this.
Householder an enthusiastic DIYer? New picture hung? Nice shelving unit above a switch?
This is as bad as some of the threads that go on for days because basic information hasn’t been given, you would be amongst the ones playing hell about it.
My holistic helmet is away for repair.
Had something few weeks ago that was (maybe) similar - the wiring to starter was just push fit and had pinged out to touch metal case of fluorescent fitting earthing the live - fast trip on mcb when closed, for obvious reasons...
Lol.
Went for the obvious visual of rose fittings first but nothing so checked florry still nothing. So thought must be something in the loft.
Opened loft hatch and a load of pellets fell out, thought strange so up we go.
Thats when the smell hit me...............
The loft was stripped bare of PVC, only bright gleaming copper to veiw. Not going to go into too much detail as you may not have eaten, Rats have been up here for ages if not years. It was two inches deep with well......lets call them pellets as for as i could see, dead ones everywhere. Have seen some bad ones of this but nothing prepared me for how bad or the smell and flies.
The place needed completely rewiring after cleaning and fumagating. client fell over when i told him, just did not think i would get one of these in this area and type of house, and he did not know !
Reply to A not so great fault today in the Australia area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
