Abs and glow plug light errors,blowing 80 amp fuse. | on ElectriciansForums
Discuss Abs and glow plug light errors,blowing 80 amp fuse. in the Auto Electrician Forum area at ElectriciansForums.net
Manchester
Hi all,newbie here,i,ll dive straight in,i have a daewoo musso 2.9td 1999,and its developed a fault,the abs light is permently on and i have no glow plug light and its a mare trying to start from cold,ive had it a 5 garages local to me,four of them started crying because they couldnt scan it,the 5th bless him has got the furthest yet he found the 3rd glow plug cable was touching the engine and causing the 80amp abs fuse to blow,he straightened the end out which is attached to glow plug and i had both lights doing what they should been great for 4 days now its blown fuse again and in back to square 1,has anyone any ideas where i go from here,im thinking its now the cable could be shorting out somewhere but m guessing,cheers all.
I'm no expert on Daewoo glow plugs but if a cable was damaged and had just been 'straigtended out' then I would be looking there again for the problem. Its probably time to replace that glow plug and or loom (and check the others wbilst you are there). I imadgine the loom could be salvaged from a breakers or possibly the ends rebuilt by an auto electrician with the correct crimp tools.
Hi shaun1,thanks for reply,the guy did bench test all plugs and they were all good,he replaced no3,because when he tested it it blew the fuse on his tester,id replaced the plug myself a week earlierxwhen my problems originally started,and i must of twisted the cable,but what sounds funny to me is the problem was already there,so dont understand why mechanic said the cable was touching engine and blowing fuse,am i right in thinking a fuse will blow because theres a short or bad ground,electrics is such a minefield very confusing.
If it's a single core connected to the glow plug, then yes if the copper core of the cable (or a connector attached to it) touches the engine it will blow a fuse because the core will be carrying 12v and the engine will be at 0v (assuming of course it's a negative earth arrangement).
If the same fuse is blowing,it would indicate a fault on the same circuit.
Although glow plugs usually fail open circuit,on occasion,they can short,internally. Is this a Merc engine?
Most of the electrical major problems I have worked on of late have been mercs with a bit of age .
It has usually been the naff harnesses. The wire turns to dry string.
As you have found out it usually affects other systems too.
Just trace it back , start where there is heat and where there is obvious corosion. Routing around manifolds , that sort of thing .
Glow plugs is not the end of the world , just keep chipping away.
Just had the 5th mechanic tell me he doesnt now no why the 80 amp fuse keeps blowing he doesnt reckon its a short in the wiring because his two wire and fuse homemade tester doesnt blow after he straightened the cable out,he said he thinks its drawing to much ampage,and said try disconnecting on glow pkug and see if that works,baffled.
Reply to Abs and glow plug light errors,blowing 80 amp fuse. in the Auto Electrician Forum area at ElectriciansForums.net
