Absolutely no idea how much to quote for this? | on ElectriciansForums
Discuss Absolutely no idea how much to quote for this? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just completed an EICR! Its taken a while to write up!
I have to emphasise that I am not recommending the chap change his crabtree CU and wylex fuse box, I am offering it as a suggestion and have made it clear that it is not dangerous. However, I am changing the bottom RCD anyway (poor trip times) and also the upper RCD enclosure (poor IP) and also the fuse box is difficult to work on due to the proximity to the meter so it may be a good idea.
I would like to give him an idea of how much it would cost to change it all to a 15 way CU and dont want to over/under quote. I usually charge around ÂŁ300 for a CU change but there is a lot more going on here and was thinking around ÂŁ500. Is that about right or a way off?
[ElectriciansForums.net] Absolutely no idea how much to quote for this?[ElectriciansForums.net] Absolutely no idea how much to quote for this?
looking at that mess, i think ÂŁ500 is spot on. assuming your eicr did not find circuit faults.
It found the poor IR readings and also a broken ring which I would rectify first!
If your customer does end up opting for an "update" it'll tidy up easy enough nice big din rail box to joint into brand new DB below so add up all your materials there's a day in the DB change to allow a chilled day, add say half a day for the faults then stick some profit on top and your sorted really
OR
fix what's not doing it's job tidy the twins up and charge half a day
SIMPLES
Reply to Absolutely no idea how much to quote for this? in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Better off with the click prw213 as it has twin screw termination.
