Ele123
AC arc welder transformer.
I tested the transformer as follows:
-All wires are separated from the switch and from each other
-There are 9 red wires, 6 gray and 2 thick uninsulated copper leads to which the main cables for the electrode holder and ground are connected.
-No wire has contact with ground.
-All red wires have mutual continuity
-All gray wires have mutual continuity
-Two thick uninsulated copper lines have mutual continuity
-There is no mutual continuity between wires of different colors, nor between any colored wires with thick uninsulated copper conductors.
- The resistance was tested and recorded in the table below, using a multimeter with a measuring range of 200 ohms.
  • The red wires were numbered at the bottom with numbers 1 to 7, two were not numbered and I marked them with 8-9A and 8-9B.
  • The gray wires were not numbered and I marked them with numbers 91 to 96.
Does anyone have an idea how this transformer works or a test method that might be useful in getting the machine up and running?
All those conductors provide different power and voltage settings and it would be highly optimistic someone from afar can tell you where it all connects.
I have a 13v AC transformer, to which wire numbers should I connect it to without destroying the windings.
This was an old arc welder with a switch input voltage of 220V - 0 - 380V
Ele123
BiH
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
AC arc welder transformer connection
DIY Electrical Advice
Ele123,
Ele123,
TrueNAS JBOD Storage Server
