AC Single Phase Motor - Expected Amp Draw | on ElectriciansForums
Discuss AC Single Phase Motor - Expected Amp Draw in the Central Heating Systems area at ElectriciansForums.net
Melbourne
Hi Forum Members
I have a 4 pole single phase 240VAC 315 watt motor from a central heating heating system that I think is bad.
It's the room fan inside the squirrel cage that sucks / pushes the air past the heat exchanger
It seems to run but very slowly. I think it's bad.
That said, there is no short to ground and when I do an earth to active and earth to neutral there is no short.
Also the resistance measurements on the coil windings are within spec.
My question is around what typical amp draw should I see against the motor when it's running with the full 240VAC ?
My clamp meter is saying it's pulling 2.9 amps.
This seems too high to me and indicates it's gone bad but I don't understand why/ how the winding resistance measurements are still good.
It still rotates nicely by hand so no mechanical issues.
My rough thoughts is that
P = V X I
Power = 240 vac X 2.9 = 696 watts
So with motor rater at 315 watts it's more than double so that must show it's bad ???
Also the name plate on the AC motor says it's 240 vac 315 watts but it's rated 3.6 amps, that doesn't make sense to me ??
Can someone explain if I can write off the motor based on the 2.9 amp draw ?
I've tested the 15uF capacitor and it tests good.
If the name plate says full load current is 3.6A at 240v
you are showing 2.9A at 240v
that seems to be about right for a motor that is not fully loaded.
remember that the rating of a motor (315w) is likely to be the output power at the shaft not the input power including all losses.
Thanks for that.
Photo of nameplate attached.
If my calculation isn't correct P = V X I + (factoring motor losses)
What is the correct formulae to work out the Amperage draw ?
Is it then possible that something is degraded in the windings like an insulation issue causing the motor to run slow ?
  • [ElectriciansForums.net] AC Single Phase Motor - Expected Amp Draw
Have you measured the rpm?
No I don't have a tool to measure RPM.
That said, I can say at speed 1 ( out of 10) the PCB sends the motor 100 vac which is correct as per the service manual the squirrel wheel turns so slowly you can put your hand in the blade if you wanted. Probably 60 - 100 rpm absolute max. Sort of just turning over
Sorry, your original post didn’t mention it was running off a speed controller.
to check motor performance against nameplate, it needs to be directly connected to a supply equivalent to the nameplate.
speed controller may be changing the voltage and the frequency and will give misleading results.
It was running around 60 rpm (approximately) with the speed controller giving it 97 VAC. At 97 VAC it was also drawing 2.8 amps ( similar to my original post amp draw) which was done via bridging active mains straight to the motor (so full 240 VAC) which also drawed around 2.9 amps
My understanding is that a 4 pole AC motor at 240 vac / 50 hz is controlled the speed by altering the frequency in Hertz.
Therefore at 97 VAC the frequency is approaching 24 hz.
Then the calculation is approximately I should have seen around (720 rpm) rather than the 60 to 100.
No, the frequency is not linked to the voltage.
you can have 100v at 25hz, it will run slower because the slip will be higher but it won’t necessarily be half its rated speed.
Hi James, yes I see the point you are making. Would be able to give me a ballpark figure on what RPM I should expect to see at the initial start up voltage which is 97VAC RMS supplied to the motor given it's rated at 1,350 rpm ?
My understanding of VFD is their alter frequency to control the speed but I could be wrong.
Even a ballpark figure plus or minus 20 % would be helpful for me. I've had the PCB tested and it's sending the right amount of voltage at 97 VAC RMS to the motor at the start up fan speed.
I thought in the range of 500 - 600 RPM. It's a motor that goes in a squirrel cage blower fan in the ceiling in a ducted gas heating system that circulates the air through the house.
With no load, I.e. disconnected from the fan
at 100v 50hz I would expect to see in the region of 1350rpm
Reply to AC Single Phase Motor - Expected Amp Draw in the Central Heating Systems area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
I have sent you my contact details where in the West Midlands are you? I am based north of coventry but travel the county and beyond you may...
