most accenta panels should work,
basically with a new panel you will be left with bell, pir, cable and rkp which should all be reasonabley mix n matchable
you must remove the wires from the tamper pair of terminals first . then link set+ to L/H tamper terminal.then power up.wait for alarm to sound, then power down, remove link and power up again. sometimes you have to do it twice.
done this 2 or 3 times, always worked for me.
What exactly needs to be disconnected then BlueToBits?
Any wiring that may be connected to the set terminal if the system installation has a remote set button. The chances are that there isn't any so there will be nothing to disconnect. See Telectrix comment #11.
Remove cables from PA connections and set + (forget terminal numbers as these changed when the expanded the Optima/Accenta from 4 to 6 then 8
Anyway power down (outside sounder may go off ignore it) link Set+ and the left hand connection of PA power up then enter 0123 to silence panel remove link the replace PA and Set+ cables if required
hello i'm new here,
i have a similar problem, my alarm went off one night when my daughter came home and i haven't been able to reset it since, i have tried the wiring thing about six times now and still nothing?? also the number eight zone light is on the keypad?? any ideas would be greatly appreciated.
thanks
paul
Accenta 6 Alarm: Lost user code
Security Alarms, Door Entry and CCTV (Public)
Luchador,
paulsanderson,
