accenta intruder alarm problem | on ElectriciansForums
Discuss accenta intruder alarm problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
sneillyboy
Hi guys hope you can help me
Have just swapped my old alarm panel for a shiny new accenta panel.
Havingcarefully noted all wiring and swapping it from old to new . How disappointed was I when powering up nothing happened except the power LED on the front lit up !!
No tones from the keys , no alarm situation when front panel was removed NOTHING !!
I await your words of wisdom ??
Cheers
So you took a note of the way it was wired and reconnected that way? Did you at any time refer to the manufacturer's wiring diagrams for the new panel?
First things first, ...power panel as it came with factory links and no wires.....this is always done first to prove panel is ok......then install one zone at a time and check....lastly connect bell box wiring. Always fit any panel this way, it saves hunting faults later.
favorite is the back tamper on the ext. sounder. take the wires out of A & T and link out. then try it.
+1 for tamper lock out would be the first thing I would check. It does sen like a tamper fault normally on the accenta.
put link in tamper on the board n try from there.
ok lets do it the long way round.....tamp linked out, bell linked out, and panel tamper spring retained......power up enter 0123....now what happens (sounds & led showing)...??
because A & T are the 0v feed to the bell and the tamper return. if either of the bell tamper switches are open circuit, there's no tamper return, so the panel sees iyt as a tamper fault.
Reply to accenta intruder alarm problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
Good luck with your project and welcome to the forum
It’s not ideal but you can splice circuits inside of the panel.
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
I know this is a forum for electrical problems but I can't find a forum for burglar alams (is there one?) Bye the by one of you may have an...
