access to main intake supply? | on ElectriciansForums
Discuss access to main intake supply? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bredon86
hi if im unable to gain access to main intake supply. do i just write n/a in the characteristics of primary supply opd.
please help?
also were else to i note this down?
If it is an install cert, then you CANNOT have any Limitations on it, and indeed it would be applicable. If it is a periodic you can put LIM in the box
mmmm If its ANY cert you can have LIMS I had one the other day installed a circuit but the main incommer was through a wall in a secure part of post office hence no reasonable access could be gained LIM was duely put on sheet added page on at end explaining reason for LIM
Just been searching for the same question, started some PIRs on apartments and having no joy tracking down a key for the meter room so I think I will be put LIM in the appropriate boxes and make a note of it on the Obs section stating that as the meter room is under control of building management then it would be reasonable to assume that the condition of equipment would be satisfactory
ive had the same problems installing new DB's in outbuildings of water treatment works. the main incomers are locked in motor control centres, with castell interlocks that prevent me opening the compartment and having a look, without isloating a towns water supply. noboad holds any info on most of these sites either, as the new water comapny is a merger of loads of smaller ones, and most of the records were lost.
Reply to access to main intake supply? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
