Add digital timer | on ElectriciansForums
Discuss Add digital timer in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
Rodrayner
leicestershire
Hi, I have a small consumer unit that provides a supply to two commando sockets outside. I need to add a timer to one of the socket so bought a cheap off the sheaf digital timer ( Greenbrook T80-C ) but struggling to work out how to connect it
[ElectriciansForums.net] Add digital timer
Top connections are 1 & 2, bottom being 3 & 4
Manual says supply to terminals 1 & 2, Terminals 3 & 4 are volt free, 3 being Live in and Live out going to Load ( presumably terminal 4 )
Can someone just tell me which connections go where please in really simple terms.
Run a Brown wire from the bottom of the relevant MCB to 1 and a second from the same place to 3.
Connect 2 to the blue terminal strip.
Connect 4 to the load.
Where in Leicestershire are you?
Reply to Add digital timer in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
