Add new outlets in house with original fuse box | on ElectriciansForums
Discuss Add new outlets in house with original fuse box in the UK Electrical Forum area at ElectriciansForums.net
cdayuk
Cheltenham
My house was built in 1968 and still has the original fuse box with wired fuses.
I want an electrician to add to the existing ring main a new spur for a combi boiler and a new dual 13A outlet.
Is it correct that in order to comply with the current regs the fuse box will have to be replaced by a modern consumer unit?
Not strictly so, however it may well be the best way to do it.
get a couple of local companies to quote.
I will be surprised however if you find a spark who will add a socket to your existing ring on rewireable fuses lol
Reply to Add new outlets in house with original fuse box in the UK Electrical Forum area at ElectriciansForums.net
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
I will soon be adding some (2 or 3) additional sockets to an existing timber stud and plasterboard partition wall, and had some questions about...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
