Discuss Add wall lights to existing lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The power would come from the light switch, unless I can take a spur from a mains socket in the room above but that means the wall lights would be on the upstairs ring main instead of a lighting circuit. Would this be acceptable or bad practice ?I agree, the lights need power!
However, not having to raggle/chase for the switches does save a lot of time and redecoration.
I’m not sure if it’s just the angle and the lighting in the photo but it seems like the insulation is suffering from a bit of heat damage on two of your blue cables in the back of the switch.
Reply to Add wall lights to existing lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
